ammazzo il meccanico
un mesetto fa il mecca mi disse che la mia macchina era un gioiellino...... oggi dopo una bella vaggata ecco il risultato.....
Tuesday,19,October,2010,13:17:02:46862
VCDS Version: Beta 912.0
Data version: 20091201
Chassis Type: 3B - VW Passat B5
Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
VIN: WVWZZZ3BZ2E094946 Mileage: 180980km/112455miles
Address 01: Engine Labels: 038-906-019-AVF.lbl
Part No: 038 906 019 EP
Component: 1,9l R4 EDC 0000SG 1442
Coding: 00002
Address 01: DTCs cleared
WVWZZZ3BZ2E094946 VWZ7Z0A3853803
2 Faults Found:
17664 - Engine Coolant Temp Sensor (G62): Open or Short to Plus
P1256 - 35-10 - - - Intermittent
18057 - Powertrain Data Bus: Missing Message from ABS Controller
P1649 - 35-00 - -
Readiness: 0 0 X X X
Address 03: ABS Brakes Labels: 4B0-614-517.lbl
Part No: 4B0 614 517 G
Component: ABS/ESP front 1328
Coding: 04255
Shop #: WSC 05311
No fault code found.
Address 08: Auto HVAC Labels: 3Bx-907-044.lbl
Part No: 3B1 907 044 H
Component: CLIMATRONIC B5GP 0006
Coding: 17000
Shop #: WSC 05311
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 C
Component: 08 AIRBAG VW6 04 0004
Coding: 12344
Shop #: WSC 05311
Address 17: Instruments Labels: 3B0-920-xx5-17.lbl
Part No: 3B0 920 826 A
Component: KOMBI+WEGFAHRSP VDO V01
Coding: 05125
Shop #: WSC 30189
1 Fault Found:
01316 - ABS Control Module
49-10 - No Communications - Intermittent
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 05314
1 Fault Found:
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 B
Component: 16 Komfortgerát HLO 0003
Coding: 00258
Shop #: WSC 05311
Part No: 1C0959801
Component: 16 Tõrsteuer.FS KLO 0003
Part No: 1C0959802A
Component: 16 Tõrsteuer.BF KLO 0002
Part No: 1C0959811
Component: 16 Tõrsteuer.HL KLO 0002
Part No: 1C0959812
Component: 16 Tõrsteuer.HR KLO 0002
End ---------------------------------------------------------------------
VCDS Beta 912.0: SRI Reset
Control Module Part Number: 3B0 920 826 A Labels: 3B0-920-xx5-17.lbl
Component:KOMBI+WEGFAHRSP VDO V01, Coding:05125
Please select an operation
Channel Description Unit Current val. New val.
02 Service Reminder Status 0 ---
40 Mileage since Service km x100 16 ---
41 Time since Service Days 8 ---
42 Min Mileage to Service km x1000 15 ---
43 Max Mileage to Service km x1000 15 ---
44 Max Time to Service Days 365 ---
Control Module Part Number: 038 906 019 EP
Component and/or Version: 1,9l R4 EDC 0000SG 1442
Software Coding: 00002
Work Shop Code: WSC 05314
Additional Info: WVWZZZ3BZ2E094946 VWZ7Z0A3853803
2 Faults Found:
P1649 - 35-00 - -
2 Faults Found:
P1649 - 35-00 - -
Shop #: WSC 05314
temperatura ok.... faceva freddo e ci sta ... MA L'ALTRO?????? sul web è tutto in inglese ..pare sia la centralina abs..... qualcuno ne sa di più?help....
ps accoppo o no il meccanico?
non accopparlo!
Non potrai più guidare la tua Passat.. :lol: ;) ;)
hai il sensore dell'acqua 8credo quello doppio che fa le bizze.. è un problema comune (io ne ho cambiati due, ormai..e tre valvole termostatiche..)
per la centralina ABS, verifica gli spinotti.. oppure, su qualche rara Passat, si potrebbero ossidare le saldature interne... o si ripassano, o va cambiata la centralina...
o, magari più semplicemente, si è ossidato lo spinotto.... :sad:
fossero tutti lì, i problemi... ho appena staccato al mecca un assegno da 1.900€ per i lavori su entrambe le mie auto..e a breve devo sostituire il Volano... quello sì, che son dolori..... ;)
la centralina, con un paio di centinaia di €, la recuperi in rete nella peggiore delle ipotesi, ed il sensore dovrebbe costarne una trentina in conce........... :P
g62 = doppio eccitatore termico o bulbo dell'acqua! si cambia tranquillamente cerca qualche discussione in merito! per gli altri errori cancellali e vedi se riappaiono! mi raccomando utilizza la procedura corretta per cancellare l'errore e non clear results dalla schermata dove hai fatto l'auto scan altrimenti non cancelli nulla!
ma il sensore h2o nn dovrebbe farlo xkè nn era a 90 ° ??? e dai anche quello... :lol: uffi.... tutto è nato da 3 beep all accensione.....
ti ripeto prova a cancellare gli errori prima di effettuare qualsiasi lavoro e vedi se si ripresentano! il bulbo costa 36 euro, mi pare di ricordare. Cmq la sua funzione è quella di rilevare la temperatura del liquido refrigerante
chiedo perdono per l'OT ma è dello stesso argomento: il vag dice i km del contakm o quelli effettivi in assoluto?
mi spiego: riporta il numero del contachilometri o quanti ne ha effettivamente percorso la vettura?
  • 13 years later...
Saluti dalla Bulgaria :)
Sunday,19,May,2024,16:17:24:16365
VIN: WVWZZZ3BZ2E094946   License Plate:
Mileage: 361940km-224899mi   Repair Order:
Chassis Type: 3B (3B - VW Passat B5 (1997 > 2005))
VIN: WVWZZZ3BZ2E094946   Mileage: 361940km-224899miles
   Coding: 00002
   Shop #: WSC 05314
   VCID: 6949FFFB7EA4DE5116D-4B1E
1 Fault Found:
17965 - Charge Pressure Control
            P1557 - 35-10 - Positive Deviation - Intermittent
   Coding: 04255
   Shop #: WSC 05311
   VCID: 259577070E707675365-5160
   Coding: 17000
   Shop #: WSC 05311
   VCID: 268A7502727B706C3EF-5160
   Coding: 12344
   Shop #: WSC 05311
   VCID: 37BB9B51B6AE0AF3869-4B1E
1 Fault Found:
00532 - Supply Voltage B+
            07-10 - Signal too Low - Intermittent
   Coding: 05125
   Shop #: WSC 00186
   VCID: 21916F131E5C8E4956D-5132
Address 19: CAN Gateway        Labels: 6N0-909-901-19.clb
   Coding: 00006
   Shop #: WSC 05314
   VCID: 704009E45AC9B462CE3-511C
   Component: 16 Komfortgerбt HLO 0003
   Coding: 00258
   Shop #: WSC 05311
   VCID: 36BA9552B2AB10FCBEF-4B1E
   Subsystem 1 - Part No: 1C0959801
   Component: 16 Tхrsteuer.FS KLO 0003
   Subsystem 2 - Part No: 1C0959802A
   Component: 16 Tхrsteuer.BF KLO 0002
   Subsystem 3 - Part No: 1C0959811
   Component: 16 Tхrsteuer.HL KLO 0002
   Subsystem 4 - Part No: 1C0959812
   Component: 16 Tхrsteuer.HR KLO 0002
5 Faults Found:
01134 - Alarm Horn (H12)
            77-00 - Internal Supply Voltage
01141 - Luggage Compartment Unlocking Switch (E165)
            27-00 - Implausible Signal
00947 - Trunk Lid remote Control Switch (E188)
            29-10 - Short to Ground - Intermittent
00928 - Locking Module for Central Locking; Front Driver Side (F220)
            27-10 - Implausible Signal - Intermittent
00930 - Locking Module for Central Locking; Rear Left (F222)
End----------(Elapsed Time: 05:21, VBatt start/end: 12.1V/12.3V)-----------
Edited by Petar
  • 2 weeks later...
  • 6 months later...
