Aiuto sono dei guasti?
liviolivio6
Ciao o apena ricevuto il mio vag oggi ed ho fato la scansione :hand:
o trovato cuesti erori ,mi aiutate a capire cosa sono ???aiuto grazie
Chassis Type: 3C0
Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 52 53 55 56 62 72 76
7D
VIN: WVWZZZ3CZ7E068825 Mileage: 97450km/60552miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Cannot be reached 1100
62-Door, Rear Left -- Status: Malfunction 1010
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
Address 19: CAN Gateway Labels: 3C0-907-530.lbl
Part No SW: 3C0 907 530 C HW: 3C0 907 951 A
Component: Gateway 007 0040
Revision: 00007000 Serial number: 0700C0682103AD
Coding: FDFD3C04C22002
Shop #: WSC 05311 000 00000
VCID: 2142E7DAC793FC14
3 Faults Found
01305 - Databus for Infotainment
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 31
Mileage: 95972 km
Time Indication: 0
Date: 2000.00.00
Time: 15:48:42
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 31
Mileage: 95972 km
Time Indication: 0
Date: 2000.00.00
Time: 15:48:45
01333 - Door Control Module; Rear Left (J388)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 96
Mileage: 96809 km
Time Indication: 0
Date: 2000.00.00
Time: 06:54:08
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 P HW: 1K0 959 795 G
Component: J388 TUER-SG HL 1114
Revision: 11005001 Serial number: 00000000565855
Coding: 0000208
VCID: 3D7A3BAA5B2BB8F4
1 Fault Found
00098 - Left Rear Central Locking (Safe) Motor (V163)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 3
Fault Frequency: 3
Reset counter: 133
Mileage: 96803 km
Time Indication: 0
non ho il VAG, ma da quel che interpreto direi che hai un problema con la serratura della porta posteriore sx..e, probabilmente, non hai una radio originale VW... :hand:
Pasquale 90
coalche aiuto?? :lol:
potrebbe essere lo switch della serratura....devi controllare se aprendo quella porta, si accandono le plafoniere interne....se non si accendono, potrebbe essere quello...
oppure nota se il computer di bordo ti segnala una porta aperta...oppure controlla se quando apri e chiudi con la chiave, quella porta si comporta correttamente...
io ho avuto un problema simile, ho rischiato che mi rimanesse bloccata la porta...avevo un filo semi-interrotto sulle cerniere.... :P
Dal difetto che presenta capisco quanto segue:
- non hai alcuna radio VW mentre il sistema probabilmente all'origine l'aveva: DAMMI CONFERMA DI QUESTO
- la porta posteriore SX ha qualche contatto difettoso oppure sono stati mossi alcuni mucroswitch troppo velocemente e questo la centralina non l'ha gradito
- il problema del CAN potrebbe essere docuto ad uno dei due precedenti.
I consigli che ti hanno dato sono ottimi.
Io farei così:
-vag com: clear logs di tutti i malfunzionamenti
- prova ad aprire e chiudere la porta post sx un po di volte con e senza la serratura e prova ad alzare e abbasare il finestrino
- riverifica con il vag
Per la radio attendo conferma.
Enry
liviolivio6
Grazie per le risposte il radio e un sony 1 dinche lo cambiato ,domani provero a cancelare gli erori e faro la prova con la porta posteriore sx :lol: e grazie a tutti per aiuto.
Ciao a tutti ,la portiera sx e aposto oara ma ho ancora questi erori che non vano via anche dopo il riset , aiuto
((((19-CAN Gateway -- Status: Malfunction 0010)))))...............
56-Radio -- Status: Cannot be reached 1100 non originale .......................
62-Door, Rear Left -- Status: OK 0000
2 Faults Found:
((((((((((((((((((((((((01305 - Databus for Infotainment ))))))))))))))))))))))))
01304 - Radio
((((((((((((19-CAN Gateway -- Status: Malfunction 0010)))))))))))))))))) ;) :(
guarda che è tutto normalissimo: la radio originale, configurata nel sistema, è collegata col sistema CAN BUS all'elettronica di bordo...
è PERFETTAMENTE LOGICO, che la scansione rilevi la mancanza di comunicazione con la SUA radio.. mica funziona per telepatia....
quello che tu chiami "errore", è semplicemente una ratificazione di qualcosa che già dovresti sapere: NON HAI LA RADIO ORIGINALE :( ...
SOLO quelle, sono CAN BUS e, quindi, comunicano con le centraline.....
