fabiopell 0 Posted February 28, 2009 Share Posted February 28, 2009 ho fatto una scansione della passat 3bg di mio fratello, aveva la spia esp (fissa) e candelette (intermittente) accese, non me li fa resettare, mi ha dato questi guasti, mi potete aiutare a capire? grazie Chassis Type: 3B - VW Passat B5 Scan: 01,02,03,08,15,16,17,19,35,36,37,46,55,56,58 Address 01 ------------------------------------------------------- Controller: 038 906 019 KD Component: 1,9l R4 EDC 0000SG 4897 Coding: 00002 Shop #: WSC 05314 WVWZZZ3BZ4******* VWZ7Z0C8723308 1 Fault Found: 16955 - Brake Switch (F): Implausible Signal P0571 - 35-10 - - - Intermittent Readiness: N/A Address 03 ------------------------------------------------------- Controller: 4B0 614 517 G Component: ABS/ESP front 3428 Coding: 04255 Shop #: WSC 05311 1 Fault Found: 00526 - Brake Light Switch-F 36-00 - Open Circuit Address 08 ------------------------------------------------------- Controller: 3B1 907 044 K Component: CLIMATRONIC B5GP 0010 Coding: 17000 Shop #: WSC 05311 No fault code found. Skipping Address 15-Airbags Address 17 ------------------------------------------------------- Controller: 3B0 920 829 A Component: KOMBI+WEGFAHRSP VDO V04 Coding: 05115 Shop #: WSC 02218 WVWZZZ3BZ******** VWZ7Z0C8723308 No fault code found. Address 19 ------------------------------------------------------- Controller: 6N0 909 901 Component: Gateway K<->CAN 0001 Coding: 00006 Shop #: WSC 05311 No fault code found. Address 46 ------------------------------------------------------- Controller: 1C0 959 799 B Component: 8S Komfortgerát HLO 0003 Coding: 00258 Shop #: WSC 05311 3 Faults Found: 01135 - Interior Monitoring Sensors 36-00 - Open Circuit 00913 - Window Regulator Switch: Front Right Driver (E81) 27-10 - Implausible Signal - Intermittent 00915 - Window Regulator Switch: Rear Right: Driver (E55) 27-10 - Implausible Signal - Intermittent Address 56 ------------------------------------------------------- Controller: 1J0 035 186 E Component: Radio BNO 0006 Coding: 05403 Shop #: WSC 05311 No fault code found. End ------------------------------------------------------- Quote Link to post Share on other sites
enry68 126 Posted February 28, 2009 Share Posted February 28, 2009 Hai 2 problemi , secondo me,: - il più importante hai l'interruttore del pedale del freno difettoso. Fallo riparare o sostituiscilo. Il fatto che si accendano gli stop non significa nulla. Quello è un interruttore a doppio corpo (diciamo così) che fornisce anche un'ulteriore informazione alla centralina. Esso è con molta probabilotà la causa delle centraline 01(motore) e 03(esp/abs). Poi hai un problema su qualche connessione degli switch dei cristalli elettrici di destra. Stesa cosa per il segnale del volumetrico. hai l'allarme volumetrico di serie ?? Comunque quello è il meno. il problema principale è l'interruttore del pedale del feno. E' normale che che ti venga segnalato in questo modo. Enrico. Quote Link to post Share on other sites
fabiopell 0 Posted February 28, 2009 Author Share Posted February 28, 2009 grazie tante, il volumetrico non saprei, lo chiedo a mio fratello, io nella mia non c'e' l'ho. Quote Link to post Share on other sites
fabiopell 0 Posted February 28, 2009 Author Share Posted February 28, 2009 una cortesia, come faccio a sapere che guasti sono? ho un pdf ma c'e' scritto solo quello che gia' mi dice il pc. come si leggono gli errori? grazie e scusate l'ignoranza........ Quote Link to post Share on other sites
enry68 126 Posted February 28, 2009 Share Posted February 28, 2009 Se ti riferisci alle note del VAG è tutti li. Poi ci vuole un pò d'esperienza. Comunque siccome la somma degli errori (simili) farebbe pensare a due interruttori guati a DX ... difficile che si rompano nello stesso modo (possibile ma improbabile) penso di più ad un connettore infilato male. Ora bisogna capiere se l'auto è stata smontata magari il problema è unasciocchezza. Quote Link to post Share on other sites
tdi4motion 5 Posted February 28, 2009 Share Posted February 28, 2009 una cortesia, come faccio a sapere che guasti sono?ho un pdf ma c'e' scritto solo quello che gia' mi dice il pc. come si leggono gli errori? grazie e scusate l'ignoranza........ http://wiki.ross-tech.com/index.php/Category:Fault_Codes qui trovi tutti i codici errore. Quote Link to post Share on other sites
fabiopell 0 Posted March 1, 2009 Author Share Posted March 1, 2009 grazie. per quanto riguarda se e' stato smontato qualcosa la risposta e' si, sono state cambiate le gomme in settimana, non vorrei che fossero i connettori delle pasticche? Quote Link to post Share on other sites
fabiopell 0 Posted March 1, 2009 Author Share Posted March 1, 2009 a proposito......... come si resetta il tagliando con il vag 311-2? a mano sono riuscito a farlo, ma con il vag non ho capito dove si fa' e come. Quote Link to post Share on other sites
tdi4motion 5 Posted March 1, 2009 Share Posted March 1, 2009 a proposito......... come si resetta il tagliando con il vag 311-2?a mano sono riuscito a farlo, ma con il vag non ho capito dove si fa' e come. sul sito ross-tech ci sono tutte le procedure!!!! Quote Link to post Share on other sites
enry68 126 Posted March 1, 2009 Share Posted March 1, 2009 Se non ricordo male si azzera il canale 2 del tachimetro. quindi 17 - instrument adaption 10 ch 2 e metti a 0 quello che dovrebbe essere a 1 Quote Link to post Share on other sites
fabiopell 0 Posted March 1, 2009 Author Share Posted March 1, 2009 grazie tante.... Quote Link to post Share on other sites
enry68 126 Posted March 1, 2009 Share Posted March 1, 2009 nulla Quote Link to post Share on other sites
Miky84 0 Posted May 11, 2020 Share Posted May 11, 2020 Ciao!qualcuno mi può aiutare ..ho un Volkswagen passat cc automatica mi e venuto fuori sul computer errore 00003.il volante non si gira più come prima ,devi tirare fortissimo per girare destra e sinistra.ce una spia rosa del servosterzo.Qualcuno mi può dire che cosa si può fare.?Grazie! Quote Link to post Share on other sites
Tuco 1,849 Posted May 11, 2020 Share Posted May 11, 2020 @Miky84. Salve Miky. Ci piacerebbe fare la Tua conoscenza in questa sezione come consuetudine fare tutti i nuovi utenti...https://www.vwgolfclub.it/forum/index.php?/forum/49-presentazioni/ e di dare una lettura al REGOLAMENTO....IL NUOVO REGOLAMENTO DEL VW GOLF CLUB ITALIA. Il Nuovo Regolamento del VW Golf Club Itali ....ti aspettiamo.... Grazie mille....e buon proseguimento.... Quote Link to post Share on other sites
