roby2040 3 Posted January 21, 2018 Share Posted January 21, 2018 salve ragazzi e da un po di giorni che la macchina ogni tanto sia caldo che a freddo non ci accende bene ho riscontrato seguenti errori penso che monti questo tipo iniettore siemens 03G130073T volevo sapere se si possono revisionare o pulire aturday,20,January,2018,17:20:33:62939 VCDS Version: Release 12.12.0 Address 01: Engine Labels: 03G-906-018-BMN.clb Control Module Part Number: 03G 906 018 EM HW: 03G 906 018 EM Component and/or Version: R4 2.0l PPD1.2 G 1184 Software Coding: 0000078 Work Shop Code: WSC 05314 000 00000 VCID: 74E73A5B174EF4BE80B-8021 4 Faults Found: 012295 - Camshaft Position Sensor (G40) P3007 - 006 - No Signal Freeze Frame: Fault Status: 01100001 Fault Priority: 0 Fault Frequency: 61 Reset counter: 40 Mileage: 130899 km Time Indication: 0 Date: 2017.02.24 Time: 19:00:02 Freeze Frame: RPM: 1280 /min Torque: 80.0 Nm Speed: 46.0 km/h Bin. Bits: 11111111 (no units): 6.0 (no units): 193.0 Time: 0.00 s 000833 - Camshaft Position Sensor (G40) P0341 - 006 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 0 Fault Frequency: 89 Reset counter: 40 Mileage: 131609 km Time Indication: 0 Date: 2017.05.11 Time: 18:41:10 Freeze Frame: RPM: 416 /min Torque: 96.0 Nm Speed: 0.0 km/h (no units): 0.0 Steering Angle: 0.00° Angle: 0.0 ° (no units): 1.0 009489 - SAE - ECM/PCM Power Relay Sense Circuit P2511 - 008 - Intermittent - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 0 Fault Frequency: 4 Reset counter: 40 Mileage: 132402 km Time Indication: 0 Date: 2017.08.19 Time: 21:40:15 Freeze Frame: RPM: 2624 /min Torque: 120.0 Nm Speed: 30.0 km/h 23.79 % Voltage: 13.79 V 9.75 % Temperature: 85.0°C 004711 - PD Unit Injector: Cylinder 3 (N242) P1267 - 006 - Regulation Range Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 0 Fault Frequency: 2 Reset counter: 13 Mileage: 133266 km Time Indication: 0 Date: 2017.11.30 Time: 06:24:24 Freeze Frame: RPM: 1632 /min Torque: 0.0 Nm Speed: 44.0 km/h 81.90 % Text: 5.125 uF Text: 11.75 mJ Text: 12 mJ Raw, Form. N/A: 000 000 000 Quote Link to post Share on other sites
Muttley74 1,987 Posted January 21, 2018 Share Posted January 21, 2018 Innanzitutto sostituisci il sensore di posizione dell'albero a camme, essendo guasto è quello che ritarda l'avviamento. Quote Link to post Share on other sites
roby2040 3 Posted January 28, 2018 Author Share Posted January 28, 2018 oggi mi sono messo a cambiare il sensore mi sono trovato con piccolo problema missa che mi tocca smontare la distribuzione porca miseria , vi allego le foto Quote Link to post Share on other sites
roby2040 3 Posted February 4, 2018 Author Share Posted February 4, 2018 salve ragazzi dopo le madonne tirate per smontare il sensore, la macchina adesso si comporta benissimo accensione perfetta saluti Quote Link to post Share on other sites
