La Mia Passat Non Raffredda Più. Compressore Da Sostituire?
Un saluto a tutti!
Ho una passat variant 2.0 170CV DSG modello 2012.
Ho fatto una lettura con il VCDS e questo il risultato:
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: Malfunction 0010
6D-Trunk Elect. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CFGB) Labels: 03L-906-018-CFF.clb
Part No SW: 03L 906 018 BD HW: 03L 907 309 N
Component: R4 2,0L EDC H25 8244
Revision: 41H25--- Serial number: 00000000000000
Coding: 001D0012047401080000
Shop #: WSC 00015 115 00000
ASAM Dataset: EV_ECM20TDI01103L906018BD 003006
ROD: EV_ECM20TDI01103L906018BD.rod
VCID: 6DD7BFEFBC132C7640B-8038
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 057 HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2703
Revision: 05351113 Serial number: 00001109271872
Coding: 0000020
Shop #: WSC 05311 000 00000
VCID: D6A5700361850FAE111-8083
Address 03: ABS Brakes Labels: 3AA-614-109.clb
Part No SW: 3AA 614 109 AD HW: 3AA 614 109 AD
Component: J104 C2 450M V552 0022
Revision: --H07--- Serial number: 00000004740218
Coding: 0121276
VCID: 6FEBA5E77E1FDE66727-803A
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 5K0 907 044 FB HW: 5K0 907 044 FB
Component: Climatronic H18 1112
Revision: 00001004
Coding: 0001004803
ASAM Dataset: EV_Climatronic A01010
ROD: EV_ClimaAutoBasis_SE36.rod
VCID: 70E9A69BAB21C19E6BD-8025
1 Fault Found:
9481988 - Air Quality Sensor
B10AF 04 [008] - Internal System Fault
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 3
Fault Frequency: 3
Reset counter: 118
Mileage: 179918 km
Date: 2052.14.24
Time: 19:04:06
Address 10: Park/Steer Assist (J446) Labels: 3AE-919-475.clb
Part No SW: 3AE 919 475 HW: 7N0 919 475
Component: PARKHILFE 8K H04 0009
Revision: -------- Serial number: 77631128110482
Coding: 118102
Shop #: WSC 99999 1023 2097151
ASAM Dataset: EV_EPHVA18VW47X0000 001003
ROD: EV_EPHVA18VW4280000_SE36.rod
VCID: FCF102AB776935FE475-80A9
Address 13: Auto Dist. Reg Labels: None
Part No SW: 3AA 907 567 HW: 3AA 907 567
Component: AC201 RDW A 036 0143
Revision: 00036000 Serial number: 00000000519497
Coding: 0010000
VCID: F7FB1D87864F16A62A7-80A2
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 R HW: 5N0 959 655 R
Component: J234__101 VW10 HI 1918
Revision: 22014000 Serial number: 003K0PMBDPLB
Coding: 0012337
VCID: 4C91126B2F49C57E375-8019
Subsystem 1 - Serial number: 6332MTS642982721
Subsystem 2 - Serial number: 6342MTS689112651
Subsystem 3 - Serial number: 6351HTS60TOQFAKJ
Subsystem 4 - Serial number: 6361HTS6CDABFAKR
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel (J527) Labels: 3C0-953-569.clb
Part No SW: 3C9 953 501 BM HW: 5K0 953 569 T
Component: LENKS.MODUL 014 0140
Revision: FF010040 Serial number: 20110926301191
Coding: 399AA50000
ASAM Dataset: EV_VW360SteerWheelUDS A03004
ROD: EV_VW360SteerWheelUDS.rod
VCID: 75E7978FD443E4B6B8B-8020
Multi Function Steering Wheel Control Module:
Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D
Component: E221__MFL-TK6 H06 0022
Coding: E30000
Address 17: Instruments (J285) Labels: 3C8-920-xxx-17.clb
Part No SW: 3AA 920 870 D HW: 3AA 920 870 D
Component: KOMBI H03 0607
Coding: 161F00
Shop #: WSC 05314 115 00000
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
ROD: EV_Kombi_UDS_VDD_RM09_VW21.rod
VCID: 336369979AB7BA8656F-8066
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 L HW: 1K0 907 951
Component: J533 Gateway H41 1620
Revision: H41 Serial number: 071011F1003199
Coding: 462006
Shop #: WSC 05314 000 00000
VCID: 397F5BBFB0DB40D69C3-806C
Address 25: Immobilizer Labels: 3C0-959-433-25.clb
Part No SW: 3AA 959 433 HW: 3AA 959 433
Component: IMMO 043 0400
Revision: 00043000 Serial number: VWZCZ000000000
Shop #: WSC 131071 1023 2097151
VCID: F6E5108381456FAE311-80A3
Subsystem 1 - Part No: 3C0 905 861 J
Component: ELV 029 0380
3C0905861J ELV 029 0380
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Component: SG EXT.PLAYER H13 0240
Revision: A1001003 Serial number: 7661076355
Coding: 010000
VCID: 295F8BFF407BF056EC3-807C
Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 3AA 959 701 A HW: 3C0 959 793 C
Component: TUER-SG FT 002 0533
Revision: 12110009 Serial number: 0003668460
Coding: 0210B7
Shop #: WSC 05311 115 00000
ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001
ROD: EV_TSGFPQ35BRFVW46X.rod
VCID: 3567578F94C3A4B678B-8060
Slave Driver:
Subsystem 1 - Part No SW: 3C0 959 703 HW: 3C0 959 795 Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 004 0407
Serial number: 00000002504826
Coding: 000090
Address 44: Steering Assist Labels: 5N1-909-144.clb
Part No SW: 5N1 909 144 M HW: 5N1 909 148 G
Component: J500__APA-BS KL.310 1002
Revision: 1AH03734 Serial number: 00112870202201
Coding: 0000258
VCID: 3C7142AB7FE975FE875-8069
Address 46: Central Conv. Labels: 3C0-959-433-46.clb
Component: KSG PQ47 ELV 043 0634
Coding: 00900A00D2830E76300494157C084F0B607801
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 47: Sound System (R12) Labels: 5K0-035-456.clb
Part No SW: 5K0 035 456 A HW: 5K0 035 456 A
Component: KonzernAmp 8K H06 0180
Revision: -------- Serial number: BP218819900927
ASAM Dataset: EV_AudioVerst8KanalBNO2 A01003
ROD: EV_AudioVerst8KanalBNO2.rod
VCID: 28598EFB5371C95EF3D-807D
Address 4F: Centr. Electr. II (J520) Labels: 1K0-907-532.clb
Part No SW: 7N0 907 532 HW: 1K0 907 951
Component: EZE_2 H41 1620
Coding: 050B0508
VCID: EFEB25E73E1F5E66F27-80BA
Subsystem 1 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H02 0220
Subsystem 2 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J394EE20SKB13 H02 0220
Subsystem 3 - Part No SW: 3AA 919 204 A HW: 3AA 919 204 A
Component: Analoguhr 004 0003
Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 3AA 959 702 A HW: 3C0 959 792 C
Component: TUER-SG BT 002 0533
Revision: 14110009 Serial number: 0003660600
Coding: 0210B6
ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
ROD: EV_TSGBPQ35BRFVW46X.rod
VCID: 3665508389C5AFAE711-8063
Slave Passenger:
Subsystem 1 - Part No SW: 3C0 959 704 HW: 3C0 959 794 Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 004 0407
Serial number: 00000002509642
Coding: 000090
1 Fault Found:
131584 - Motor for Rear Window Regulator
B11EE 54 [008] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 103
Mileage: 178602 km
Date: 2052.14.15
Time: 17:30:22
Address 53: Parking Brake Labels: 3AA-907-801.clb
Part No SW: 3AA 907 801 G HW: 3AA 907 801 G
Component: J540 EPB4 VW-64783 0009
Revision: H19 Serial number: 00000000322003
Coding: 0022167
VCID: 3567578F5CC3A4B678B-8060
Address 56: Radio (J5503) Labels: None
Part No SW: 3F8 035 190 F HW: 6C8 035 1<5 F
Component: Rddio RCA510 000 0707
Revision: 05000001 Serial number: VRZ1Z3L7376696
Coding: 01040000010011
Shop #: WSC 70850 002 00000
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 7N0 907 534 HW: 1K0 907 951
Component: Batt.regelung H41 1620
Coding: 030B185A
VCID: F1EF239F282B4896E43-80A4
Subsystem 1 - Part No SW: 1K0 915 181 H HW: 1K0 915 181 A
Component: J367-BDM H07 0180
Address 69: Trailer (J345) Labels: 7N0-907-383.clb
Part No SW: 7N0 907 383 HW: 7N0 907 383
Component: Anhaenger H09 0101
Revision: 3I001002 Serial number: 00000160304593
Coding: 4106040000000000
VCID: F3E3299752377A8616F-80A6
1 Fault Found:
02565 - Trailer; Right Turn Signals (M63)
010 - Open or Short to Plus - MIL ON
Freeze Frame:
Fault Status: 11101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 69
Mileage: 179380 km
Time Indication: 0
Date: 2052.14.18
Time: 23:33:45
Address 77: Telephone (J412) Labels: 3C8-035-730-A.clb
Part No SW: 3C8 035 730 B HW: 3C8 035 730 B
Component: Telefon 011 0723
Revision: -------- Serial number: 35909603251983
Coding: 020000000000000000000000
ASAM Dataset: EV_UHVPremi A02003
ROD: EV_UHVPremi_SE36.rod
VCID: 224D9CD3354D230EAD9-8077
End ---------------------------------------------------------------------
Ho pensato poi di cancellare tutti gli errori dalla memoria. Il risultato è che a livello pratico non è cambiato nulla, e facendo però di nuovo la lettura non compare più nessun errore:
08-Auto HVAC -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
69-Trailer -- Status: OK 0000
VCID: 6DD7BFEFBC132C49B4D-8038
Readiness: 0 0 0 0 1
Coding: 0000020
VCID: 56A5F003E1858F91657-8003
Coding: 0121276
VCID: 6FEBA5E77E1FDE59861-803A
Revision: 00001004
Coding: 0001004803
VCID: 70E9A69BAB21C1A19FB-8025
Address 09: Cent. Elect. (J519) Labels: 3AA-937-087.clb
Part No SW: 3AA 937 087 D HW: 3AA 937 087 D
Component: BCM PQ47 H 413 0455
Revision: BB413001
Coding: 000000000000000000180080540081E403510088426D87606480C7200041
VCID: 3B7341B7BAE772F97A9-806E
Subsystem 1 - Part No SW: 3AB 955 419 HW: 3AB 955 419 Labels: 1KX-955-119.CLB
Component: Wischer 21091 10 0603
Coding: 00B795
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 171011 05 54 0403
Coding: 024D2A
Coding: 118102
ROD: EV_EPHVA18VW47X0000.rod
VCID: 7CF182ABF769B5C1333-8029
Coding: 0010000
VCID: 77FB9D87064F96995E1-8022
Coding: 0012337
VCID: 4C91126B2F49C541C33-8019
Coding: 399AA50000
VCID: 75E7978FD443E4894CD-8020
Coding: E30000
Coding: 161F00
ROD: EV_Kombi_UDS_VDD_RM09_SE25.rod
VCID: 336369979AB7BAB9A29-8066
Coding: 462006
VCID: 397F5BBFB0DB40E9685-806C
VCID: 76E590830145EF91457-8023
Coding: 010000
VCID: 295F8BFF407BF069185-807C
Coding: 0210B7
VCID: 3567578F94C3A4898CD-8060
Slave Driver:
Coding: 000090
Coding: 0000258
VCID: 3C7142AB7FE975C1733-8069
VCID: 28598EFB5371C96107B-807D
Coding: 050B0508
VCID: 6FEBA5E7BE1FDE59861-803A
Coding: 0210B6
VCID: 3665508389C5AF91857-8063
Slave Passenger:
Coding: 000090
Coding: 0022167
VCID: 3567578F5CC3A4898CD-8060
Address 56: Radio (J0503) Labels: 5M0-035-1xx-56.clb
Part No SW: 3C8 035 195 F HW: 3C8 035 195 F
Component: Radio RCD510 050 0207
Revision: 00000001 Serial number: VWZ1Z3L7676696
Coding: 01010000010011
VCID: 2B5371F74A87E279EA9-807E
Coding: 030B185A
VCID: 71EFA39FA82BC8A9905-8024
VCID: 73E3A997D237FAB9629-8026
Address 6D: Trunk Elect. Labels: None
Part No SW: 3C9 827 383 J HW: 3C9 827 383 J
Component: J605 HECKDECKEL 0804
Revision: 00H52001
VCID: 38795EBB4BD159E197B-806D
Subsystem 1 - Part No: 3C9 827 384 J
Component: J756 HECKDECKEL 0804
Subsystem 2 - Serial number: 1100H52001001A0317ÿ
VCID: 224D9CD3354D233159F-8077
End-------------------------(Elapsed Time: 04:47)--------------------------
C'è qualcuno che può aiutarmi?
Mille grazie!!
sul fatto che non hai più errori?... o metti in corto qualcosa, o te ne devi fare una ragione.... :sad:
Vorrei capire perché il clima non funziona....
E perché prima avevo l'errore e adesso no?
Forse perché l'evento che ha causato il malfunzionamento si è verificato una sola volta? Ma se fosse così e io adesso ho resettayo tutti gli errori...portando l'auto in concessionaria non sapranno che pesci pigliare?
Grazie...
che il clima non funziona, lo apprendo ora... ma, hai provato ad inserirlo, e POI a rifare la scansione?...
se non va, un errore deve comparire...ma compare solo nel momento in cui attivi l'utenza malfunzionante...
giusto per dovere di cronaca, sei passato da un elettrauto che si occupa di climatizzazione?... magari, manca solo il gas... è una causa molto frequente, fra chi non viaggia 365 giorni l'anno col clima in automatico... stando fermo le guarnizioni si seccano, lentamente il gas fuoriesce e, quando lo riaccendi dopo tre mesi di inattività, ormai di gas non ce n'è più....
L'avevo portata in un'officina e mi era stato detto che c'era il compressore rotto...
Ho viaggiato tutto l'inverno senza risolvere il problema dato che non era così indispensabile.
Ora però fa caldo e vorrei capire se è davvero il compressore o se è solo scarico l'impianto.
Credevo che sarebbe stato sufficiente collegare la VCDS per scoprirlo, ma mi sa che così non è!
Ho resettato tutto e poi ho percorso 400km provando più volte ad accendere il clima: non raffredda e dalla ultima scansione non risulta più neanche un errore!
Modificato: da cecciaosce
  • Like 1
se ti han detto che il compressore non funziona, avranno i loro motivi...
basta che gli dici che se, però, cambiando il compressore, non funziona lo stesso... non gli paghi il lavoro e nemmeno il pezzo....
Non metto in dubbio quello che mi è stato detto...
Siccome però ho l'interfaccia mi sarebbe piaciuto capirne qualcosa... È possibile?
Tu mi sai dire che tipo di errore e' e perché ora non esce più?
Grazie! ?
sinceramente, non saprei... la mia non ha il sensore qualità dell'aria... per cui, ignoro come possa influire sul funzionamento del compressore... al massimo, potrebbe influire sulla paratia del ricircolo, non certo inibire l'accensione...
ergo: presumo che, col tuo problema, c'entri come i cavoli a merenda.....
Tuo stesso problema..mancava il gas!!!
dammi retta fai una ricarica che poi te lo dice subito se è scarico il macchinario...a me volevano fottermi 800 euro e alla fine era il macchinario dell'officina rotto.
fortuna che ho provato da un distributore per curiosità, mai fermarsi dal primo
  • 4 weeks later...
Buonasera a tutti!
Ho notato la vite torx svitata e spannata sul piattello del compressore che è un Delphi 5n0820803e.
Da quanto mi hanno spiegato, forse è sufficiente cambiare il piattello.
Qualcuno ne sa qualcosa?
  • 2 weeks later...
Ho avuto lo stesso problema in questi giorni sulla mia vecchia Mazda6 che abbiamo ancora in casa.
Pensavamo fosse il compressore ma oggi l'abbiamo portata da un nostro cliente meccanico ed era la puleggia: la vite non teneva più e non la faceva avvicinare a sufficienza al compressore per attivarlo. Risolto con 30€ compresa la ricarica del clima (che otto anni era solo leggermente scarico).
Falla controllare che magari te la cavi veramente con poco!
