Franz 91 17 Inserita: 22 aprile 2012 Share Inserita: 22 aprile 2012 Salve Gente :gci oggi ho fatto una scansione alla passat e...... Sunday,22,April,2012,11:58:02:60804 VCDS Version: Release 10.6.0 Data version: 20100630 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 3B - VW Passat B5 Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77 Mileage: 256370km/159300miles ------------------------------------------------------------------------------- Address 01: Engine Labels: Redir Fail! Part No: 038 906 018 P Component: 1,9l R4 EDC 00SG 1629 Coding: 00002 Shop #: WSC 05311 VCID: 234E6A7A9BBD 1 Fault Found: 01266 - Glow Plug Relay (J52) 31-10 - Open or Short to Ground - Intermittent Readiness: N/A ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8E0-614-111-ABS.lbl Part No: 8E0 614 111 AB Component: ABS 5.3 FRONT D00 Shop #: BB 24548 VCID: 5EB81B8EF05F No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 3Bx-907-044.lbl Part No: 3B1 907 044 B Component: CLIMATRONIC V 1.0.0 Coding: 05000 Shop #: WSC 05311 VCID: 204465768AAB No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 1J0-909-60x-VW3.lbl Part No: 1J0 909 607 A Component: AIRBAG VW3 S V04 Coding: 00065 Shop #: WSC 05311 VCID: 2B5E825AF36D No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 3B0-919-xxx-17.lbl Part No: 3B1 919 860 C Component: B5-KOMBIINSTR. VDO V01 Coding: 04140 Shop #: WSC 00000 VCID: 2A50875EFC97 Part No: IMMO Component: IDENTNR: VWZ7Z0W1180391 IMMO-IDENTNR: VWZ7Z0W1180391 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 1J0-959-799.lbl Part No: 1J0 959 799 Q Component: 38 Zentral-SG Komf. 0001 Coding: 04097 Shop #: WSC 05311 VCID: 4C9CE1C656A3 Part No: 1J1959801D Component: 38 Tõrsteuerger. FS0001F Part No: 1J1959802E Component: 38 Tõrsteuerger. BF0001B Part No: 1J4959811D Component: 38 Tõrsteuerger. HL0001H Part No: 1J4959812D Component: 38 Tõrsteuerger. HR0001r 3 Faults Found: 01329 - Convenience System Data Bus in Emergency Mode 35-00 - - 00930 - Locking Module for Central Locking; Rear Left (F222) 27-00 - Implausible Signal 00931 - Locking Module for Central Locking; Rear Right (F223) 27-00 - Implausible Signal End --------------------------------------------------------------------- Che vuol dì? :mad: Link al messaggio Condividi su altri siti
Eraldi 164 Inserita: 22 aprile 2012 Autore Share Inserita: 22 aprile 2012 (modificato) Salve Gente :gci oggi ho fatto una scansione alla passat e...... Sunday,22,April,2012,11:58:02:60804 VCDS Version: Release 10.6.0 Data version: 20100630 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 3B - VW Passat B5 Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77 Mileage: 256370km/159300miles ------------------------------------------------------------------------------- Address 01: Engine Labels: Redir Fail! Part No: 038 906 018 P Component: 1,9l R4 EDC 00SG 1629 Coding: 00002 Shop #: WSC 05311 VCID: 234E6A7A9BBD 1 Fault Found: 01266 - Glow Plug Relay (J52) 31-10 - Open or Short to Ground - Intermittent Readiness: N/A ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8E0-614-111-ABS.lbl Part No: 8E0 614 111 AB Component: ABS 5.3 FRONT D00 Shop #: BB 24548 VCID: 5EB81B8EF05F No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 3Bx-907-044.lbl Part No: 3B1 907 044 B Component: CLIMATRONIC V 1.0.0 Coding: 05000 Shop #: WSC 05311 VCID: 204465768AAB No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 1J0-909-60x-VW3.lbl Part No: 1J0 909 607 A Component: AIRBAG VW3 S V04 Coding: 00065 Shop #: WSC 05311 VCID: 2B5E825AF36D No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 3B0-919-xxx-17.lbl Part No: 3B1 919 860 C Component: B5-KOMBIINSTR. VDO V01 Coding: 04140 Shop #: WSC 00000 VCID: 2A50875EFC97 Part No: IMMO Component: IDENTNR: VWZ7Z0W1180391 IMMO-IDENTNR: VWZ7Z0W1180391 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 1J0-959-799.lbl Part No: 1J0 959 799 Q Component: 38 Zentral-SG Komf. 0001 Coding: 04097 Shop #: WSC 05311 VCID: 4C9CE1C656A3 Part No: 1J1959801D Component: 38 Tõrsteuerger. FS0001F Part No: 1J1959802E Component: 38 Tõrsteuerger. BF0001B Part No: 1J4959811D Component: 38 Tõrsteuerger. HL0001H Part No: 1J4959812D Component: 38 Tõrsteuerger. HR0001r 3 Faults Found: 01329 - Convenience System Data Bus in Emergency Mode 35-00 - - 00930 - Locking Module for Central Locking; Rear Left (F222) 27-00 - Implausible Signal 00931 - Locking Module for Central Locking; Rear Right (F223) 27-00 - Implausible Signal End --------------------------------------------------------------------- Che vuol dì? :mad: Fra Parte bene al Freddo ? Come funziona la chiusura ? Mi sa che devi contralere le porte posteriore Modificato: 22 aprile 2012 da Eraldi Link al messaggio Condividi su altri siti
Franz 91 17 Inserita: 22 aprile 2012 Share Inserita: 22 aprile 2012 ciao Eraldi ;) Si, parte bene anche se fa freddo..., cosa può essere? :xe?: La porta posteriore destra è quella che mi dà noie <_< , perchè quando chiudo tutte le porte(da dentro) quella lì mi rimane aperta.. :mad: Appena ho tempo la smonto... :angry: Comunque mi preoccupa il primo errore quello dell'Engine... :mad: Link al messaggio Condividi su altri siti
Eraldi 164 Inserita: 22 aprile 2012 Autore Share Inserita: 22 aprile 2012 ciao Eraldi ;) Si, parte bene anche se fa freddo..., cosa può essere? :xe?: La porta posteriore destra è quella che mi dà noie <_< , perchè quando chiudo tutte le porte(da dentro) quella lì mi rimane aperta.. :mad: Appena ho tempo la smonto... :angry: Comunque mi preoccupa il primo errore quello dell'Engine... :mad: E il relè delle candelette. Gli hai cancellato gli errori ? Link al messaggio Condividi su altri siti
Franz 91 17 Inserita: 22 aprile 2012 Share Inserita: 22 aprile 2012 relè!?!?!? :unsure: Che numero? Si, gli errori li ho cancellati ma si presentano ancora quando faccio la scansione.. :mad: Link al messaggio Condividi su altri siti
Eraldi 164 Inserita: 22 aprile 2012 Autore Share Inserita: 22 aprile 2012 relè!?!?!? :unsure: Che numero? Si, gli errori li ho cancellati ma si presentano ancora quando faccio la scansione.. :mad: Hai toccato qualche fusibile da solo?O cambiato qualche candeletta ? Come si comporte la spia delle candelette appena si apre il quadro? Link al messaggio Condividi su altri siti
Franz 91 17 Inserita: 22 aprile 2012 Share Inserita: 22 aprile 2012 Hai toccato qualche fusibile da solo?O cambiato qualche candeletta ? Come si comporte la spia delle candelette appena si apre il quadro? Non ho toccato niente.. La spia si comporta bene,..accendo il quadro e dopo 2 - 3 secondi si spegne la spia.. Link al messaggio Condividi su altri siti
Muttley74 1968 Inserita: 22 aprile 2012 Share Inserita: 22 aprile 2012 La porta quando la chiudi ti rimane aperta, ma se la chiudi manualmente quando la apri funziona? Se funziona prova a buttare disossidante elettrico sulla serratura. Link al messaggio Condividi su altri siti
Franz 91 17 Inserita: 23 aprile 2012 Share Inserita: 23 aprile 2012 La porta quando la chiudi ti rimane aperta, ma se la chiudi manualmente quando la apri funziona? Se funziona prova a buttare disossidante elettrico sulla serratura. si funziona.. :ok: seguiro il tuo consiglio ;) Link al messaggio Condividi su altri siti
mikesavoia 606 Inserita: 30 aprile 2012 Share Inserita: 30 aprile 2012 (modificato) edit Modificato: 14 maggio 2012 da mikesavoia Link al messaggio Condividi su altri siti
130Comfortline2004 0 Inserita: 22 aprile 2016 Share Inserita: 22 aprile 2016 Ciao a tutti, facendo una scansione ho trovato i seguenti errori, qualcuno sa gentilmente tradurmeli? Grazie Address 17: Instruments Labels: 3B0-920-xx5-17.lbl Part No: 3B0 920 809 C Component: KOMBI+WEGFAHRSP VDO V03 Coding: 07115 Shop #: WSC 00000 1 Fault Found: 01336 - Data Bus for Comfort System 80-10 - Single-Wire Operation - Intermittent ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl Part No: 6N0 909 901 Component: Gateway K<->CAN 0001 Coding: 00006 Shop #: WSC 05311 VCID: F0EFB64BB056489EE43-5072 1 Fault Found: 01336 - Data Bus for Comfort System 80-10 - Single-Wire Operation - Intermittent ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 1C0-959-799.lbl Part No: 1C0 959 799 B Component: 85 Komfortgerát HLO 003 Coding: 00259 Shop #: WSC 05311 VCID: 3663C05312B2A6AE7EF-4A3A Subsystem 1 - Part No: 1C1959801 Component: 85 Tõrsteuer.FS KLO 0202 Subsystem 2 - Part No: 1C1959802 Component: 85 Tõrsteuer.BF KLO 0202 Subsystem 3 - Part No: 1C0959811 Component: 85 Tõrsteuer.HL KLO 0202 Subsystem 4 - Part No: 1C0959812 Component: 85 Tõrsteuer.HR KLO 0202 1 Fault Found: 01336 - Data Bus for Comfort System 80-10 - Single-Wire Operation - Intermittent Link al messaggio Condividi su altri siti
Muttley74 1968 Inserita: 22 aprile 2016 Share Inserita: 22 aprile 2016 http://wiki.ross-tech.com/wiki/index.php/01336 Link al messaggio Condividi su altri siti
130Comfortline2004 0 Inserita: 22 aprile 2016 Share Inserita: 22 aprile 2016 http://wiki.ross-tech.com/wiki/index.php/01336 Grazie, quindi se non ho capito male c'è qualche "contatto" sui "moduli" delle portiere che va con un singolo filo... Link al messaggio Condividi su altri siti
Pasquale 90 999 Inserita: 22 aprile 2016 Share Inserita: 22 aprile 2016 Si è un errore insensato che non ho mai capito....anche perché con un solo filo non rileverebbe i moduli.... Inviato dal mio Nexus 5 utilizzando Tapatalk Link al messaggio Condividi su altri siti
